badboy_6120
try to increase the input voltage to 180VAc
I connect the input through a 600w hair dryer and I have 190V without any load
Then I connect a Heater Element to the out put
The voltage drops to 135 Volts and it drew 2 Amp
Then I remove the dryer and connect the input directly to the 220V ( in my case our outlet voltage is around 240Volts)
The output voltage without any load was 202 Volts
and when I connect the Heater to the output it drops to 185 Volts and it drew 2.8A
I leave the smps with load connected to it for about 30 Sec
The mosfets didn't heat at all but the output diodes get a little hot (I haven't installed the heatsink yet)
