Yes you can solder the mosfets. But show waves at G of mosfets. Not connected 220vac
Dear Microsim
I want to do my ETD49 transformer as below:
1/2 primary >> 11 turns
1/2 Secondary >> 13 turns
1/2 Primary >> 11 turns
My goal : 80-0-80 Volts
I'm gonna use 10*0.1mm for primary and 15*0.1mm for secondary
but the thickness of this much wire seems a little low to me for this much power
I attach a picture of primary wire that I made
Is this ok?
That's thin, I would recommend at least 30x0.1mm for 500w
I did this because you told in post 113 yourself
http://www.diysmps.com/forums/showthread.php?79-1kW-smps-project-(based-on-MicrosiM-design)/page12
How about this?
Primary : 60*0.1mm
Secundary : 100*0.1mm
for at least 1000W
Did you monitor the heat of the MOsfets?
try to increase the input voltage to 180VAc
