Greetings ...
First sorry for my bad english..
I am a new member on this forum, my name is afton, Iam come from East Java Indonesia .
I want to ask about a replacement transformer EI38-1 what? because here the transformer is difficult to get it
ETD39
ETD29
these transformers are good choice
afton
after I watched the scheme ,the transformer EI38-1 function is to provide a voltage source IC 7815, really like it ?
if using ETD39 and ETD29 what does not need to winding back to 230VAC input and adjust its output?
thank you for instructions.
afton
please prompts brother @microsim,
how to primary and secondary windings, if I use ETD39 or ETD29 that gap or ungap?while the IR2110 I plan to replace it with GDT ...
thanks
Hello microsim i want to ask if its possible to have your eagle designe files because i would like to add this part to make it variable voltage and current ?
Or if you have time to do for us thanks in advance :)
Bahman_am
hi.
Thank you so much MicrosiM.
I start smps with your design and your guides about two years ago.
and now i built this.
1000w smps with :
soft start.
temperature control (fans and cut out)
overload protect
outputs: +-15v , 5v , 48v , 12v , +-80v
everything is OK.
thank you MicrosiM.
hi.
1000w smps with :
soft start.
overload protect
everything is OK.
thank you MicrosiM.
Very nice looking SMPS. Thanks for sharing
I dont have any Eagle files for either versions of the SMPS, Ludo published them somewhere here.
Weller
Hi,
I'm building a SMPS based on a schematic placed earlier in this thread. I scaled it up to 2kW.
Transformer is winded by a Chinese company.
I use a viper26 to supply the sg3525 and ir2110.
Hi,
Hello can we see your modifications in the schematic please because i'm also working on 2.4kw... it will be helpful if you share the schematics thanks..
Weller
I share the schematics only if its working. So, please wait a few weeks when I have tested the whole circuit.
sa030
Hi Weller,
I want to make 2kW SMPS too. What is finally winding of your transformer? Did you reach wanted 2x90V with only 2x4 turns? Also, about primary, have you thought 2x8 turns?
vdij
KA3525+GDT+G20N50+ETD44, +-75V, +5V, -5V, +12V, F-60kHz, 1kW. Test.
Hello Everyone
For a while I found this thread and I was interested to build this SMPS (Ludo3232 and Microsim design)
But I haven't got the time until now
I want to build this 1KW SMPS but honestly I'm a bit confused because I don't know which version to build that would definitely work and is 100% tested
and I know "Zoky 2" build the 3.11 version on post #198 and page 20
http://www.diysmps.com/forums/showthread.php?79-1kW-smps-project-(based-on-MicrosiM-design)/page20
but He never posted his final result
So now Mir Microsim which version is fully tested and will work
also you said in post #441 on page 45 to change SG3525 connection as your attachment
I don't now what to do
Also if I know which one is the working one, I will build the PCB for everyone to use with correct components and connections
Please guide me
I really need to build this SMPS for my amplifier
Thanks in advance
SowaZ
Hi guys, I'm new :)
I join to ur question badboy, and I have a few, other question:
-Can I do this SMPS without oscilloscope?
-Which PCB and schematic+partlist are the best
-How much $$ parts for this project
Thanks guys, sorry for my eng, Im from pl :D
