demykiko
Thanks
The schematic is in post no42. The C1 and R1 are sensing the AC component at the series capacitor at half bridge converter (the two 470nF caps are dynamicly seen as the ~~1uF single capacitor), that voltage is rectified with D1 and D1, R2 is load resistor or potentiometer for trigger level adjustment, voltage on R1 is filtered with small capacitor (bigger the cap = longer delay). V_out is your triggering voltage, some of the controllers use 0,6V level, I have used transistor here to pull down the Vcc , so I need approx 0,6-0,7V base-emmiter voltage to get the protection trigerd.
Soon I will post complete smps project, I have the boards nearly ready.
