Maxter 3600
engel
and this,
i hope this help,but the layout i believe change by provider or site post it for free download,i dont know but it look like an edited,i will try to search again for that site
  • 3k6.zip
engel
the amp are made in spain
and there is a local forum there called FOROS de ELECTRONICA,somebody posted
guy name john molato
engel
try to look @ this photo you will find name john mulato at the bottom center
michelle
maxter driving pcb
hi greetings
pin no 6 has 68k resistor to ground pcb has 5.1 k from pin no 6 to ground could any one tell
which is correct value
thanking you
michelle
michelle
hi aldemarrar
greetings thanks for the circuit working can you tell bias voltage over emitter resistances
thanking you
michelle
michelle
step driver for maxter 3600
hi
greetings
1 100 ohm base resistances to mje 15032 33 should be 1 WATT EACH
2 1kiloohm resistances also should be 1 WATT EACH
3 51 KILOHM is correct value instead of 5,1 kiloohm between pin no 6 of ic and ground
STEP DRIVER PCB IS ALSO ATTACHED
  • circuito_2jpg_157.zip
  • circuito_1jpg_168.zip
michelle
hi Asquare
greetings its from john mullato i have not made it so i cant say how it works rest of it can be found on diy site
foros de electronics
thanking you
michelle
michelle
schematic of stepdriver
hope this helps diyers step drive schematic
thanking you
michelle
  • planos_197.rar
michelle
hi asquare
greetings DRIVER STAGE WORKS PERFECTLY will post pcb of stepdrive pcb a clear one after testing it
thanking you
michelle
michelle
original maxter step drive schematic
here is the original maxter step drive schematic
thanking you
michelle
michelle
maxter dc out
hi diyers
greetings maxter tested in ab class using 8 pairs crisp sound very clear on switching on with
speaker connected you will hear motorboating sound dc voltage present but if connected with delay on or dc protector delay on amplifier dc problem is solved ampifier works excellent WILL BE ATTACHING
STEP DRIVER HOPE IT WORKS WELL will post step driver and pcb if tests are good
thanking you
michelle
