Maxter 3600
irvynejay
aster 3.6k 5 pairs for test
testing 123
irvynejay
Master 3.6k with orig step driver
Works Great than the my other step
voltage 62 122 +/-
michelle
hi diyers
greetings this MAXTER AMP is comming of age just be patient lots of testing being done with different steps different supply voltages
then everything will be put on diysmps as i said from begining very good amp
thanking you
michelle
aldemarar
It makes me happy that they this one working the circuit that it they donates, is a great amplifier
me alegra que les este funcionando el circuito que les done,es un gran amplificador
saludos desde colombia
irvynejay
master 3k6 7 pairs
Hello master on 7 pairs with signal,clip,power,h rail indacator
7 pairs still good response but driver side is very stressful
unbalance trigger on step drive +side trigger faster than -side ( i hope i can fix this)
next test applying triple ef on output stage to solve the problem of driver stage
irvynejay
All files are in this thread pls read from first and end of this thread,
aldemarar,michelle,engel have contribute information on this amp
all you need is read,compare,analyzed,build and test
my progress on this project will be posted here files,modification,test and fixes will be shared after several test were done,,..
special Thanx to the Forum,Mr Mullato,aldemarar
irvynejay
update
master 3k6
i just found and fix the unbalance voltage out of the step by following the original values of master 3k6 change some value of resistors and add 1 5k variable
now voltage out +/- on step are now balance
step driver have trim pot to adjust +high rail only
tested in full range and sub its stunning response
mkubawat
Good job irvynejay
Please tell us what changes you made ​​in circuit , How much HV & LV was kept during observation & why connect LED with both diode
irvynejay
62/122 -/+ LED are indicators for high rail is triggering its on original step of master 3k6
changes was made, i replace 2 47k to 4.7k and 2.7k to 270k from the input of the step after 1n4007 and added 5k trimmer series with 2.2k on +side input of step
Why did i change it? because once the the step triggers both rails is not balance so i try to follow the original set up on input of the step to adjust +side of the HV
file attach for reference
i far as i notice upon surfing the net looking for answer the driver board is copied on crest audio and the step driver is from master DPU 3k6
Hello irvynejay
Nice work
In post no #74 i see all picture of amp ,i see 3 led circuit with two transistor circuit(H rail indacator,signal) , Plz can u post for all diyers
