Ah, what the hell, i'm in a "generous" mood
Here's how far i got with the main board, as well.
You might spot a few differences:
1) As i've mentioned before, i found a 2x9Vac transformer in my closet that's a different size to the EI38 on ludo's board
2) I've also got some vertical (F456) fuse holders; quite handy for saving some board space
3) i'm switching the relay through an npn transistor, since i only have a few 24v relays in my "stock", so... Why not put them to use?
4) i'll need this to be a single-supply (not symmetrical), so just one output (but with two connectors each)
5) You'll also spot some input filtering. In addition to that, i'm planning to use some "scavenged" IEC sockets from computer smps's, with attached X/Y caps
I haven't yet decided if i'll try to source a 7815, or i'll stick in a LM317 regulator in there...
So far, the big board's around 15x15cm
