i`have done mounting this amp into CPU casing. Second module i didnt make any pre-test upon finish all component because i`m very confident with this amp. First power up i just make little mistake by connecting +/- HV to +/- LV, hahahahaha, and i`ve protection power up signal when i see led power for +/- HV does not turn on. So i`ve check many time with component all is correct. After few power on and off, there is no fuse blown, at each power rail and at main supply. then few mins later i just check power supply connection and i found wrong connection between +/- HV and +/- LV. i just made error when connecting +/- LV with +/- 130 vdc and +/- HV with +/-65 vdc.
But there is no component burn or blown, even fuse all is fine. Then i correct it back for the power supply connection, and YEY!! amp is up and come with clear music and powefull, i`ll post the picture later here with full setup. I use 2.5 KVA trafo wind by myself which i keep it long time ago. I didnt use it before i dont have high power amp for it. Now i have 2kw class H amp which i think match for this 2.5 kva trafo .
To anyone who want high-end and powerfull amp should get this amp for stereo and its hard to burn this amp with fully working protection . Thanks to Microsim for the design and help from MJ777 for helping me. Full volume and play with hard bass almost no distortion at all
best regards,
Azmi.
best regards,
Azmi.
