MJ777 can u give me part name for DCOM1 and DCOM2 diode, i`ve the board and almost complete the component, few part i need is VTL5C4 and those diode.
ohh, Thanks for the replay MJ777. I`ll post the progress here until this amp finish.
one more can u take high quality picture with large size so i can refer to it, since this amp have many components so i need carefully mount it for the first time.
pm sent. check it out
i`ve got dc offset 0.002vdc. testing voltage +68 / +34 / 0 / -34 / -68 VDC (Using ir2153 smps) with dual trafo configuration. All run smooth, no component overheat. I`ll test the sound today hmmm... wanna listen to class H amp how deep it can run. Later i`ll do with increase the supply voltage up to double +/- 45 so it will be +90 / +45 / 0 / -45 / -90. What do you think MJ777 and Microsim ? .
best regards,
Azmi.
