the schema high power with fan control but the input caps that's what to be increased to about 200vlts x 1000uf. I've also corrected the voltage adjustment, this works for me in real life. Sadly, i cant use a potential meter only zeener diodes, but works perfectly and is stable with or without load.
In order for you to change voltage adjust the zeener diodes e.g. if you want +/-40v you use zeeners which will sum up to 80v e.g. 60v and 20v or 70v and 10v etc. I've tried the version with irf740 and it works perfectly, I want to build the one with irfp460 for a bit more power. Here are the schems, I will post the artwork later. The current protection is working perfectly just adjusting the preset potential meter vr1 will help you choose the current you want. For my testing I loaded two 100wts bulbs and the protection responded even to that load.
My transormer turns ratio are
>>primary 21 - 0 -13turns,
>> secondary is 9 turns 0-9 turns
>>Aux for fan and IC control 4turns
The other small former
>>Current protect former small from an old ups i see the primary turns are 3turns, the secondary are many, i assume they are 100 turns
It works perfectly with more turns on the primary side, my previous experiments with transformer gate-drive showed that it used less current on the mains if i used more primary turns but you guys can simulate and tell me it i'm wrong
