pls post pdf file or abigger image components and turns not visiblesomething for smps diyers
warm regards
michelle
warm regards
michelle
the schema high power with fan control but the input caps that's what to be increased to about 200vlts x 1000uf. I've also corrected the voltage adjustment, this works for me in real life. Sadly, i cant use a potential meter only zeener diodes, but works perfectly and is stable with or without load.
In order for you to change voltage adjust the zeener diodes e.g. if you want +/-40v you use zeeners which will sum up to 80v e.g. 60v and 20v or 70v and 10v etc. I've tried the version with irf740 and it works perfectly, I want to build the one with irfp460 for a bit more power. Here are the schems, I will post the artwork later. The current protection is working perfectly just adjusting the preset potential meter vr1 will help you choose the current you want. For my testing I loaded two 100wts bulbs and the protection responded even to that load.
This cannot be true because there is no output differential inductor used in secondary after diodes to hold energy and perform regulation. You are sending feedback thru opto+zener to error amp of SG3525 for regulating output by varying dutycycle, but where is the output inductor?????????????
Flyback operation is totally different than what you are doing as a halfbridge stage driving primary of transformer. In flyback you dont need full bridge rectification because the supply is working in one quadrant only, not like in half bridge which is using 2 quadrants.
hi all i managed to use this mode of voltage control and it is working i get +/-36vlts dc the smps is cool and working o.k. i have been listening to it all day with class d 200wts amp http://www.diysmps.com/forums/showthread.php?237-Class-D-200-Wrms-with-2-mosfet-cheap/page16
hi Stewin ,
what kind of transformer this smps ? (airgap or ungap )??? if air gap how mm ?
thanks
Renotrend
