irf540 or irf540z?
two channels one is two pairs irf540 the other is two pairs irf540n
irf540 or irf540z?
That schematic has an error,has any one tried the non ucd version?
If i want to use IRFB4020 what value should i use for the gate resistors? P.s Nice project Stewin,i hope that you will post the new diagram with the replaced feedback.
Good luck.
no problem brother. don't need to do so now that i've found a couple of 24v DPDT relays from my way older power amp project.To paskal:
Its very hard now to change Relay because its all very tite and close, but I'll try... If I do that, your output coil have to be external from amp board true the wires, because I have to move relays down, closer to heatsink...
at 90v you'll have ~63vrms. if there's no shortage of current you'll get 496w rms into 8 ohm. for such high power i think you're better off running bridged into 8 ohm. reduces the bus pumping effect and should ease the load on your ground return current. in my experience it'll also help reduce possibility of ground loop problem.How much power it can deliver this project in 8 ohm at 90v (with all pairs of IRFB4227) ?
