when you refer to use full bridge it means to put two modules in paralell? Or to use a full bridge diagram ? I think the result is the same
not in parallel, but in series. one of the modules will drive half of the load. meaning one module will see 4 ohm, another module will see another 4 ohm. they both drive the positive and negative pole out of phase from each other. each module at half the load will see you get about twice the power from each module.when you refer to use full bridge it means to put two modules in paralell? Or to use a full bridge diagram ? I think the result is the same
Hi Steve can you post the PCB pdf file for the amp in post #202 ?
Thanks!
did i say how AWESOME this forum is? you guys are the most awesome bunch of people that i've ever came across in *any* DIY forum.
two thumbs up for the development being done at this forum. you guys are so willing to help. never seen such willingness in an internet forum before.
thanks michelle and ionutzxpoHi Steven
greetings nice to hear non ucd is performing well
warm regards
michelle
is the ac detect necessary in this circuit? the 555 reset pin is already tied to the supply rail through q2. i think that should already provide instantaneous turn off to the relay once the power is cut.pls guys help me out with the ac detect. how can i in co-operate the ac detect in this circuit??? and will the protect side and overcurrent temp sence work??
Hi Stewin
greetings for 5.1 volt supply caps 1mfd should be 100 volts or greater on 4 pairs how much output is expected
why .22 current sensing resistors on both sides just check ocp of TRIELL amp works good try it
warm regards
michelle
