Oh , My god sorry for your scope.
very very thanks for sharing somethings like this issues.
so , it's very important to use isolation transformer for powering the scope , but the smps connect directly to the main AC lines , it's right ?
the older versions of schematics had a lot of problems and maybe not work ! the last version is here : ( 16V SMPS and SMD Parts included ) , but i'm not test it yet , i'm not guarantee the operation of circuit.
now i'm working on pcb , it's difficult.
some people working hard on projects and another people just DOWNLOAD and enjoy !
I don't know what problems you may face in old design?
Using SMPS as AUX supply is really nice thing
People like you are rare, people who work, and making research, improving things. but finally you will get the experience and results!
Just a question, isn´t it better to power the smps through isolation transformer and leave the scope the way it is? I think that when you lift the scope´s ground and measure on mains, you are likely to have 320VDC on the scope´s chassis. Not a good thing.
Offcourse the isolation transformer would need to handle the power of the smps, but for initial troubleshooting you could do with a 100W isolation transformer just to make measurments safer.
Have you started PCB design?
Just a quick question here regarding mesurements scope manufacturers recommend making differential measurements using the tip of both probes and the math function of the scope. Scope remains grounded and smps as well. I didn't see anyone mention this is there any reason?
Microsim, you nevere used a scope in differential mode? Just set both channels to the same v/div in add mode, set one channel on invert, and go measuring
