Hi there..-) , i can't believe 08-21-2011 until 02-07-2012 !!
i don't know how to apologize MicrosiM and others for delay about 6 month !
but really , i didn't have any enough free times to work on my smps.
anyway , I'm really sorry about that.
I've started working on smps since 2 days ago , stranded 10x0.15mm wires for primary.
i have some questions about transformer , is this steps are correct :
(look at schematic of transformer at attachments)
1-Make 3mm margin from both side of bobbin
2-Primary Section 1 :
Start on pins 1,2 > Winding 9 Turns of 10x0.15mm stranded wires > finish on pins 5,6
3-three Layers of mylar tape
4-Secondary(40v) Section 1 :
Start on Pins 19,20 > Winding 5 Turns of 15x0.15mm stranded Wires > finish on pins 17,18
5-two layers of mylar tape
6-Secondary(40v) Section 2
Start on pins 17,18 > Winding 5 Turns of 15x0.15mm stranded wires > finish on pins 15,16
7-two layers of mylar tape
8-Secondary(24v) Section 1 :
Start on pin 13 > winding 3 turns of 3x0.15mm stranded wires > finish on pin 12
9-two layers of mylar tape
10-Secondary(24v) Section 2 :
Start on pin 12 > winding 3 turns of 3x0.15mm stranded wires > finish on pin 11
11-three layers of mylar tape
12-Primary Section 2 :
Start on pins 5,6 > Winding 9 Turns of 10x0.15mm stranded wires > finish on pins 9,10
13-three layers of mylar tape
14-good job
I'm also tested gate driver and over current circuits on the board. results are available on the attachments.
the bad thing about O.C protector is we have to turn smps of to reset the protector.
any solution ?
