1.5 KW Class D amplifier based on IRS2092, Commercial
Status
Not open for further replies.
Password, schematic even its very basic amplifier,
But will be shown ONLY to some one who can develop it to the DIY.
Make a PCB.
And this time he will provide me with deposit in order to prove that he will make it, I cannot take more risky chances like we did with out last cheater.
michelle
Hello
Pergunta Obrigatória:
Qual é a cor normalmente atribuída aos bombeiros?
Hi Luizcpimenta
greetings can you please translate the above lines in english google could not please help out
warm regards
michelle
dineshkom
Hellow sir,i am from india ,here very difficult to get IRS2092, But i got from RS india online , I am very interesting this project, we waiting for scematic Password. old password not working.
engmarcos5
I understand your concern ...
I've seen this practice in other forums (MEGADRUM) was used and a mechanism for protection.
Since this is a forum, the intention is to see and discuss ideas ..
If the circuit is good and interesting to many, I think it's worth ...
The most difficult is the power supply .. Full range, small ...
The IR2092 has been established as an amplifier very good and affordable.
If more people are interested we can work on a solution.
But something has to be restricted to the forum ok?
Commercial designs, Even if they are very close to the application notes, they will remain commercial.
Releasing that design to the DIY as a KIT will be good thing, but that should be done in the right way.
engmarcos5
Dear MicroSim,
Could I pass the password so that I analyze this possibility ... I use ALTIUM Designer;
Could devote several hours to develop and propose a PCI considering all associated DIYs!
It is common for certain components present in the SMD package; To be a true DIY, we need all the components involved are DIL.
To avoid problems, I leave the final disclosure on your own ok?
thank you
AB-Tech
Hi MicrosiM
Can you send me the password.
Designing a 4 layers PCB is not a problem for me.
But I think that according to route complexity, I would have some technical questions to ask you.
Kind regards
AB-Tech
soerdjanto
send me paswod pls
michelle
Hows this
HOWS THIS 2500 WATTS
irs 2092
gate drivers ics
2 ohm load
mosfets IRFP 4768
OR MOSFETS IXFH88N30P
warm regards
michelle
bkastel1
irs 2092
gate drivers ics
2 ohm load
mosfets IRFP 4768
warm regards
michelle
Hi michelle,
this looks really nice. Here I would invest time and money to built it. Do you think you could share schematics?
Status
